brhunt2021's avatar
brhunt2021
Bonjour/mDNS for Apple printing
Hello,
We have an environment with a series of M4300 switches connected to one core M4300 switch.
The core switched handles internal routing between 8 vlans.
We have some apple clients on two vlans that need to access printers on a third vlan.
We need to forward Bonjour "advertising" packets from printers on vlan 40 to clients on vlans 80 and 90.
I have seen a number of links discussing Bonjour/mDNS, but none that match up with what we are needing to do.
Can someone give us some guildance on how to set up this Bonjour forwarding environment?
Thanks.
Bryan Hunt
  • schumaku's avatar
    schumaku
    What you are behind is Multcast Routing. No idea of the M4300 Series does offer this feature. LaurentMa svp.
    • brhunt2021's avatar
      brhunt2021
      schumaku,
      The M4300 does have the capability of multicast routing, but I have never set this up before.  So looking for some help with the various settings needed for each of the vlans.
      Thanks.
      Bryan Hunt
  • NeilS's avatar
    NeilS
    NETGEAR Expert
    Hi Bryan,
    For your Bonjour/mDNS environment with VLAN 80, 90 and 40, please use the following console commands:
    Access the console via TeraTerm/PuTTY.
    User:admin
    Password:***********
    (M4300)>enable
    (M4300)#config
    (M4300)(Config)#ip mroute static-multicast 224.0.0.251 80,90,40
    (M4300)(Config)#exit
    (M4300)#save
    Thank you..
ProSupport for Business
