AWENA's avatar
AWENA
Bricked Netgear M4300-52G (GSM4352S) via "Erase Permanent Storage" from CLI
Hello, accidentally deleted the Permanent Storage via CLI
found this article but it didn't help:
https://alastair.d-silva.org/bricked-netgear-m5300-switch-erase-permanent-storage
   m4300r2> fatload usb 0:1 ${loadaddr} /boot.stk
   Unknown command 'fatload' - try 'help'
I understand that must execute the following command: "ubifsload"
but I don't know the syntax options "<addr> <filename>"
Please, help
Now I have the following in terminal:
U-Boot 2012.10-00245-g79946b8c89 (Feb 21 2018 - 17:08:40)VerNo=1.0.0.11
UBIFS error (pid 0): ubifs_get_sb: cannot open "ubi:fs", error -19
UBIFS error (pid 0): ubifs_mount: Error reading superblock on volume 'ubi:fs' errno=-19!
ubifsmount - mount UBIFS volume
Usage:
ubifsmount <volume-name>
- mount 'volume-name' volume
UBIFS not mounted, use ubifs mount to mount volume first!
ubifsload - load file from an UBIFS filesystem
Usage:
ubifsload <addr> <filename> [bytes]
- load file 'filename' to address 'addr'
ERROR: can't get kernel image!
Saving Environment to SPI Flash...
Usage:
Usage:
ETH LINK UP: 1000FD
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Retry count exceeded; starting again
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    AWENA,
    Welcome to the community! 🙂
    I suggest you to open a support ticket with the NETGEAR Support Team at anytime here for technical assistance.  Kindly state your concern and the steps you did in trying to solve the problem.
    DaneA
    NETGEAR Community Team
    • AWENA's avatar
      AWENA
      Thanks for the answer. But isn't there any instruction: how to restore software?
      I read the NETGEAR CLI user manual, but did not find the information I needed, maybe I was looking in the wrong place?
  • I had the same problem and stumbled upon this thread.  I had luck recovering from the same state by following the steps in my post here:
    https://community.netgear.com/t5/Managed-Switches/Recover-from-uboot-interface-on-M4300-52G-GSM4352S/td-p/2368758
    My method did require a TFTP server, but theoretically the other methods to transfer files should work too.  I think my biggest hurdle was figuring out the proper load address which I finally got by printing the environment before issuing other commands.  That got me to the operational code utility and then doing a "Load Code Update Package" restored the switch to an operational state for me.
