defiant2
Apr 13, 2016Follower
Bridge Ports on Switch
I have a client that used to have a direct attach cable between two hosts. Now, they want to add a switch in the mix to be able to extend the capability to multiple hosts. They are only using UDP p...
JohnRo
Apr 14, 2016NETGEAR Employee Retired
Hello defiant2,
Welcome to the community!
I believe link aggregation (LAG) can be used if the hosts have the capability to use LAG as well. Click here for more information and example. Can you provide a diagram of what you are trying to accomplish?Other members here might be able to suggest a different setup.
Thanks,
