MKBKC
Nov 21, 2017Aspirant
Can I create VLANS at my current firmware version on my MODEL M5300-28G-POE+
I am having issues: 1) Creating a VLAN on management switch 1 (Stack of 8) 2) Assigning that VLAN to another switch in the stack (Switch 5, Ports 1,3,5,7,9,& 11) Basically my plan is to create the...
- Nov 27, 2017
If ever you are referring about creating VLANs on the M5300-28G-POE+ switch, kindly access and read the article below as your reference guide:
How to configure a VLAN on a NETGEAR managed switch
About upgrading the firmware in a ladderized manner, kindly do it as I have mentioned on my previous response. You can download the firmware version for the M5300-28G-POE+ switch here.
DaneA
NETGEAR Community Team
DaneA
Nov 23, 2017NETGEAR Employee Retired
Hi MKBKC,
You should be able to create VLANs even if the firmware of your M5300-28G-POE+ switch is on firmware v10.0.0.44. However, it would be best if your M5300-28G-POE+ switch is on the latest firmware version.
If ever you decide to upgrade the firmware, I recommend that you do it in a ladderized manner. First, upgrade the firmware from 10.0.0.44 to v10.0.0.53. Then, upgrade from v10.0.0.53 to v11.0.0.10 and so on until you reach the latest firmware v11.0.0.31. Be reminded to perform a factory reset after upgrading the firmware to the latest version then reconfigure it from scratch in order to start clean using the latest firmware version.
DaneA
