MKBKC's avatar
MKBKC
Can I create VLANS at my current firmware version on my MODEL M5300-28G-POE+
I am having issues: 1) Creating a VLAN on management switch 1 (Stack of 8) 2) Assigning that VLAN to another switch in the stack (Switch 5, Ports 1,3,5,7,9,& 11) Basically my plan is to create the...
  • DaneA's avatar
    DaneA
    Nov 27, 2017
    MKBKC,
    If ever you are referring about creating VLANs on the M5300-28G-POE+ switch, kindly access and read the article below as your reference guide:
    How to configure a VLAN on a NETGEAR managed switch
    About upgrading the firmware in a ladderized manner, kindly do it as I have mentioned on my previous response.  You can download the firmware version for the  M5300-28G-POE+ switch here.
    DaneA
    NETGEAR Community Team
