Joris-DLabs
Jun 21, 2023Tutor
Can't rename Port Channel in CLI - MX4300-96X
Hello,
I'm trying to rename a port channel through CLI. I haven't got any error but when I check with the show command it appears that my modification was not apply.
I've tried with multiple character (caps, no caps, dash, no dash, ...) and I got the same problem.
I've also tried to finish the configuration of my PC/LAG (port affectation, ...), my port channel is still not rename but all my other operation was apply.
My firmware version is : 10.0.17.12
There is my CLI output :
(M4300-96X) (Config)#port-channel name lag 1 LAG-NAS-ARCH-01
(M4300-96X) (Config)#show port-channel all
Log. Channel Admin Load Mbr Device/ Port Port
Intf Name Min Link Mode Type Balance Ports Timeout Speed Active
lag 1 ch1 1 Down Dis. Dyn. 2 1/1/1 actor/long 10G Full False
partner/long
1/1/2 actor/long 10G Full False
partner/long
lag 2 ch2 1 Down Dis. Dyn. 2
lag 3 ch3 1 Down Dis. Dyn. 2
Thanks in advance for your help.
I have figured out that one port of my PC was shutdown.
After enabled it again it as works.
I hope that could've help some one.
1 Reply
