niekn
Dec 01, 2016Aspirant
rename Attached Devices
When I look under "Attached Devices" in the router I see a lot of device names which have a meaningless names for me
like android-2637812647862. By checking the MAC adres or the IP adress at that devices i can find out which devices it is.
But it would be nice that i can change the name of these devices in my router, is that possible ???
i already installed the app "genie" on my smartphone. And there i can changed the names, but the router wil not take over these names.
the router which i have is: WNDR4500 – N900
That's true. The unit has been EOL for a while.
- ElaineMNETGEAR Employee Retired
Welcome to the community, niekn
If you see Access Control feature under Security, you may change the device name there by turning on the feature.
Or see Address Reservation feature.
When you turn on Access Control and select the device, do you see Edit to be available for you to edit the device name?
