DavidA2014
Jan 16, 2017Aspirant
Can't set IP management address on M4300-8X8F switch
Hi I can't set the IP management address on our M4300-8X8F switch: (M4300-8X8F) #config
(M4300-8X8F) (Config)#ip management vlan 1 192.168.1.5 255.255.255.0
Failed to configure the IPv4 Ma...
LaurentMa
Jan 16, 2017NETGEAR Expert
Hi DavidA2014
(From M4300 CLI Manual page 58)
Can you make sure 192.168.1.5 isn't used anywhere else, for instance as Routing interface on a physical port, or as L3 IP interface on another VLAN; or even more likely on your out-of-band (OOB, serviceport)? For the OOB port, if that's the case and if you don't plan to use it because you don't have separated management network, you should clear it this way at first:
(M4300-8X8F) (Config)#serviceport protocol none (M4300-8X8F) (Config)#serviceport ip none
Then, please use these commands, to specify the source IP address for all applications, including RADIUS, TACACS, DNS, SNTP, SNMP, and SysLog. Although VLAN 1 is default Management source interface on the in-band side, maybe your previous configuration attemps cleared that default. So let's reset the IPv4 management interface and re-do the configuration:
(M4300-8X8F) (Config)#no ip management (M4300-8X8F) (Config)#ip management source-interface vlan 1
Let us know how it goes - if I wasn't spot on, the Community will continue to help you.
DavidA2014
Hi Laurant
Thanks for your reply. I tried your commands but failed early on:
(M4300-8X8F) >enable
% Invalid input detected at '^' marker.and:
(M4300-8X8F) (Config)#no ip management (M4300-8X8F) (Config)#ip management source-interface vlan 1 (M4300-8X8F) (Config)#ip management vlan 1 192.168.1.5 255.255.255.0 Failed to configure the IPv4 Management Interface
what am I doing wrong?
- LaurentMaJan 16, 2017NETGEAR Expert
Sorry, the serviceport protocol command isn't in Global Config mode but in general Exec mode per the M4300 CLI Manual page 58.
So first set of commands should be:
(M4300-8X8F) #serviceport protocol none (M4300-8X8F) #serviceport ip none
(M4300-8X8F) #Then second set of commands still, in Global Config mode:
(M4300-8X8F) (Config)#Let us know how it goes - if I wasn't spot on, the Community will continue to help you.
