jsherry
Apr 03, 2018Follower
Certificate of Volatility
I need a certificate of volatility fo the Netgear Prosafe M5300-28G-POE+. It seems that these are only available by requesting support and being provided a temp URL for download. Why isn't this ...
- Apr 04, 2018
Here is the letter of volatility for M5300-28G-POE+(GSM7228PSv1h2). No password needed and the link will expire after 48 hour period.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Apr 04, 2018NETGEAR Employee Retired
Hi jsherry,
Welcome to our community! :)
I already requested for the letter of volatility of M5300-28G-POE+. I'll let you know once I got it.
- JohnC_VApr 04, 2018NETGEAR Employee Retired
