output
Aug 14, 2024Aspirant
Configuring the management LAN on an M4100-26G-POE
For home use, I bought a used M4100-26G-POE as a replacement for my JGS-516PE. Primary reason for this, is the fact that the JGS516 exposes the management interface untagged on all ports, which I do ...
ErwinL
Sep 03, 2024NETGEAR Moderator
Hello output
And welcome to the NETGEAR Community! 🙂
Please allow me to check if I understand you correctly. So you want to prevent all devices wired connected to M4100-26G-POE from having access to the web UI page of the switch? I also assume that your VLAN1 does not have any IP set nor have aquired any IP from DHCP server is this correct? Also your VLAN 10 does not have DHCP server and may I also ask if you created your VLAN 10 under Routing tab?
Have a lovely day,
Erwin
Netgear Team
