H3LD3R
Feb 28, 2023Aspirant
Connect 2 gs324T switches with 2 vlans both together.
So here is my problem. I have two GS324T switches and i have made two vlans on each switch both the same. 1t/m12 + 25&26 are my LAN ports and 13t/m 24 are my WAN ports. The software version ...
schumaku
Feb 28, 2023Guru - Experienced User
Based on the information supplied, I'm a little bit lost what makes up the two VLAN, what IP subnets are intended, and how the VLANs with multiple ports are interconnected.
- H3LD3RFeb 28, 2023Aspirant
I understand! Thanks for replying. I have made a small drawing so i hope this makes it more clear.
What i wanted to create were just simple two vlan's that act like seperate switches inside the 324.
But im not a network professional and i have had struggles with this!- schumakuFeb 28, 2023Guru - Experienced User
Still unclear about the 1t/m12 13t/m24 notation.
To establish a VLAN 1 resp. a VLAN 13 "LAN" connection, the ports need to be untagged to the respective VLAN ID and the PVID must be set accordingly, too.
- H3LD3RFeb 28, 2023AspirantAh Yes, they are just the ports i use in the vlan. So vlan 1 is also Id 1 and 2 id 2 on both and all ports in both vlans are untagged
