iihookie
Jan 29, 2018Aspirant
Connection issues with new swicth, Help please ! GS105 Prosafe
Good evening all ! I'm wondering if anyone has had this issue or could perhaps point me in the right direction please. I've just purcahsed a Netgear Prosafe GS105 switch for my home network to repla...
iihookie
Jan 30, 2018Aspirant
Thanks for your detailed reply Hopchen, the faceplates in the walls have been wired as "straight through" I have used a cable tester to test between the 2 rooms and the results have come back as ok.
Ive been doing a little more reading into the cables though... In your opinion would it matter what i use between the router - faceplate and the switch ?
I'm currently using straight through patch cables from the router to the faceplate then into the switch. would it make any difference if i were to use crossover cable ?
Many thanks
Hopchen
Jan 30, 2018Prodigy
Hi again,
As you know, the issue is that when you patch your house with cabling, the Auto MDI/MDI-X might have issues working. In that case, you need ensure you are using correct cables for connecting devices.
I would keep it simple. Your house is cabled as straight through. So, do the same between router and faceplate. Use a standard straight through cable. Even do the same between the faceplate and the switch. See if the Auto MDI/MDI-X works (i.e. you see LED activity on the ports). If not, then simply swap the cable between the faceplate and the switch to a cross-over instead.
I hope that makes sense :)
Cheers
