pbrady
Nov 01, 2020Aspirant
Creating a Routing Interface
Hi there, I am trying to create a new vlan with routing enabled on my Netgear M5300-28G3. I have created the VLAN no problems, assigned some ports and PVIDs, I can see MACs coming through for the...
- Nov 16, 2020
Hi Retired_Member,
Sorry for thge slow response. I actually ended up resolving the issue although not in the ideal way. I was trying to create a VLAN for the 192.168.155.0/24 subnet, and this would not work. However I followed the exact same steps for the network 192.168.170.0/24 and it worked, so I'm happy with things for the moment.
Thanks!
Retired_Member
Nov 02, 2020Hi pbrady
Welcome to Community!
It's ok that you have create routing VLAN and add member ports. Have you set IP address on this routing VLAN interface?
For further analysis,Could you please provide the tech-support file of the Switch:
How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
https://kb.netgear.com/31439/How-do-I-send-diagnostic-files-from-my-Managed-Switch-to-NETGEAR-community-moderators
Eric
- pbradyNov 16, 2020Aspirant
Hi Retired_Member,
Thanks!
