ClemensD's avatar
Mar 29, 2018
IP Address Conflict between Routing Interface and Interface vlan
Hello,
we are using a management vlan for our switch einvironment. Therefore we configure the specified vlan interface with the appropriate ip address. Furthermore we set the management vlan interface on the same ip address.
If the switch is booting the log file is showing the following entry:
IP Address Conflict between Routing Interface and Interface vlan xxx.
Do we misunderstand these two parameters? Must both ip addresses are different?
Thanks,
Clemens
  • Hello,
    the final update, i guess.
    after some time of researching Netgear has been solved my issue with firmware 12.0.4.10.
    It will we available for download soon.
    Best,
    Clemens
    • DaneA's avatar
      DaneA
      NETGEAR Employee Retired
      Hi ClemensD,
      Welcome to the community! :)
      I found out that you have already opened a support ticket with NETGEAR Support and still ongoing.  You may share here in the community about the progress of your online support ticket.
      DaneA
      NETGEAR Community Team
      • ClemensD's avatar
        ClemensD
        Tutor
        Hi DaneA,
        if i have further information about the result i will post it here. Actually the Netgear support cannot reproduce the issue. This may caused of different steps during the initial setup via ezsetup.
        Normally we use configuration templates für each specific switch device type.
        Best,
        Clemens
ProSupport for Business
