ClemensD
Mar 29, 2018Tutor
IP Address Conflict between Routing Interface and Interface vlan
Hello, we are using a management vlan for our switch einvironment. Therefore we configure the specified vlan interface with the appropriate ip address. Furthermore we set the management vlan inte...
- Jun 11, 2018
Hello,
the final update, i guess.
after some time of researching Netgear has been solved my issue with firmware 12.0.4.10.
It will we available for download soon.
Best,
Clemens
ClemensD
Mar 29, 2018Tutor
Netgear Support contacted.
Thanks, Clemens
DaneA
Apr 01, 2018NETGEAR Employee Retired
Hi ClemensD,
Welcome to the community! :)
I found out that you have already opened a support ticket with NETGEAR Support and still ongoing. You may share here in the community about the progress of your online support ticket.
DaneA
NETGEAR Community Team
- ClemensDApr 03, 2018Tutor
Hi DaneA,
if i have further information about the result i will post it here. Actually the Netgear support cannot reproduce the issue. This may caused of different steps during the initial setup via ezsetup.
Normally we use configuration templates für each specific switch device type.
Best,
Clemens
- ClemensDMay 29, 2018Tutor
Hello,
for further analysis my case was redirected to the Netgear Engineering Team.
Best,
Clemens
- DaneAJun 04, 2018NETGEAR Employee Retired
Hi ClemensD,
Thanks for the update. I also inquired about the update of your ongoing support ticket with NETGEAR Support and found out that the engineering team is working on a code that might fix the problem.
Feel free to post here any update about your support ticket with NETGEAR Support.
DaneANETGEAR Community Team
