scruffmeister's avatar
Mar 13, 2020
Creating Trunks on GS switches
I've inherited a flat network using a number of Netgear GS724TP switches. I have some experience of networking but not with Netgear devices. My aim is to create trunks between the switches and setup some VLANs to separate some of our devices that don't need to communicate.
I've had a look at this article, but what is not clear to me is if I create 3 VLANs, do I need to go onto each VLAN in "Switching - VLAN - Advanced - VLAN Membership" and set the trunk ports to "T", or is there some way to just tell the switch just once that a port will be the trunk for every single VLAN the device knows about, now and in the future (i.e. like you can on Ubiquiti)?
Obviously it's not too hard if you only have a couple of VLANs, but if you had 10 VLANs and 10 switches in your network - that's a lot of "T"s you have to insert and check which seems a bit error prone! Also, what happens if you introduce a new VLAN, do you just have to remember to add it to the trunk?
Many thanks.
  • schumaku's avatar
    schumaku
    GARP/GVRP should be available on (all?) the Smart Managed Pro (GSxxxT, XSxxxT) switch models..
    • scruffmeister's avatar
      scruffmeister
      Hi,
      That sounds promising, can you elaborate how I can actually put this into practice on the network I descibed?
      Thanks
ProSupport for Business
