bseif
Oct 23, 2019Follower
Default Gateway
I have two GS748T switches that I am using to create a LAN. The LAN will not be connected to the public internet. What should I set the default gateway to? Is a default gateway necessary in this case...
schumaku
Oct 24, 2019Guru - Experienced User
If there is really no firewall or router allowing connectivity to other IP subnetorks, reserve an IPv4 address (organisational, typically .1, sometimes .254) form the IPv4 subnet used on that LAN, and enter this address in the switch (and the connected devices or IoT).
