NGSC101Usr's avatar
NGSC101Usr
Detected port speed
H All,   Can anyone help with the following...   I have a HDBASET device connected to this switch and it operates at GB speed as per vendor, passing audio/video, full HD and 4k/2k. Despite this, ...
  • JohnRo's avatar
    JohnRo
    May 20, 2016
    Hello NGSC101Usr,
    Yes, that is true however this switch it has some limitation compared to the Layer 2+ and Layer 3 models. By default, it is set to Auto for 1GB and all other options are only for lower speeds. I believe this is by design. It can be used on a VPN network, yes. On its own it does NOT have a VPN capability, remember that this is only a ProSafe Plus switch and not a firewall/router.
    Thanks,
ProSupport for Business
