attilay2k
Nov 25, 2020Aspirant
DHCP reservation
good evening everyone I created my dhcp pools, but now I have about twenty devices to which I have to set a fixed ip address, via reservation. The M4100 allows the creation of a maximum of 16 po...
- Nov 30, 2020
Hi attilay2k
Sorry to be the messenger for the news below
You are right, one static binding per DHCP pool, and maximum number of DHCP pools in M4100 is 16.
So we can only get one DHCP pool for your dynamic addresses and 15 static binding's using the pools 2-16.
For your information, the maximum number of DHCP pools can be found in the Platform Constants section of the Tech Specs in the M4100 datasheet.
The M4300 switches offer 256 pools and would help you.
Maybe you could consider the new M4250 switches, they also offer 256 pools.
There is model called M4250-10G2F-PoE+ (GSM4212P-100NAS in the US) with 10x1G ports and 2xSFP uplinks
I hope this helps!
attilay2k
Nov 28, 2020Aspirant
thanks for your feedback
but can you please explain me how to add static IP-MAC pairs? via CLI or WebInterface, as you prefer
each example i'd found won't let me create the association or give me an error message
schumaku
Nov 28, 2020Guru - Experienced User
You can use the Web UI or the CLI as referenced before https://kb.netgear.com/21933/How-do-I-configure-a-Dynamic-Host-Configuration-Protocol-DHCP-reservation-using-CLI-commands-on-my-managed-switch - the point is the somewhat miselading documentation - you don't create a new pool for each new entry. The "manual-pool" is the pool where you can add multiple entries ...
- attilay2kNov 28, 2020Aspirant
hi schumaku
i tried, but get the following error
(M4100-D12G) >enable (M4100-D12G) #config (M4100-D12G) (Config)#service dhcp (M4100-D12G) (Config)#ip dhcp pool pool_manual (M4100-D12G) (Config-dhcp-pool)#client-name myphone1 (M4100-D12G) (Config-dhcp-pool)#hardware-address 46:24:XX:XX:XX:XX (M4100-D12G) (Config-dhcp-pool)#host 10.XX.XX.16 255.255.255.0 (M4100-D12G) (Config-dhcp-pool)#client-identifier 01:46:24:XX:XX:XX:XX (M4100-D12G) (Config-dhcp-pool)#client-name myphone2 (M4100-D12G) (Config-dhcp-pool)#hardware-address 66:02:XX:XX:XX:XX Couldn't set hardware address.
now in the web gui i see the new "pool_manual" with the myphone1 informations
- LaurentMaNov 30, 2020NETGEAR Expert
Hi attilay2k
I hope this helps!
- attilay2kNov 30, 2020Aspirant
Thanks
- Feb 21, 2022Retired_Member
