oxArt2Wave
Dec 07, 2017Aspirant
DHCP server ip pool limit on ProSafe M4100
Hi, I'm trying out the DHCP server feature on the Prosafe M4100-26-POE. After reading the guide, I successfully created a IP pool. However I can't create more than 15 reserverations. Tried bot...
oxArt2Wave
Dec 08, 2017Aspirant
Hi @Hopchen
Thank you for point out the limit in the data sheet. But that think Netgear is not be honest with customer. Peolple read the datasheet will think it means 16 DHCP Dynamic pools. It should not include other type such as (Unallocated and Manual).
I'm not trying to create 16 DHCP Dynamic pools. I created a single dynamic pool with a /24 subnet. Then started to create manual reservations within the subnet range by following the https://kb.netgear.com/21933/How-do-I-configure-a-Dynamic-Host-Configuration-Protocol-DHCP-reservation-using-CLI-commands-on-my-managed-switch. The web interface KB document suggests the same: https://kb.netgear.com/21934/How-do-I-configure-a-Dynamic-Host-Configuration-Protocol-DHCP-reservation-using-the-web-interface-on-my-managed-switch. There is no way of creating reservations within same DHCP pool configuration. Hence, each reservation will take one from the limit of 16.
Hopchen
Dec 08, 2017Prodigy
Hi again,
Thanks for clarification. I understand what you are doing now. I've left for the day, but let me take a look at it, in our lab, when back Monday.
Cheers
- HopchenDec 11, 2017Prodigy
Hi oxArt2Wave
You did the config correctly. Reservations will require a separate "pool". The problem is then of course that the switch will only hold a maximum of 16 pools. Unfortunately, there is not much you can do about that.
Is it possible that you can use static IPs instead, on the end devices?
Thanks- oxArt2WaveDec 11, 2017Aspirant
Hi Hopchen,
Thank you for verifying the configuration. At this moment, the M4100 is not suitable for my needs to act as DHCP server. I like the fact I can configure DHCP options per reservation. But 15 reservations is just not enough. I hope netgear can relax this hard limit. Or enforce the limit for Dynamic pools only.
And the static IP assignments defeat the purpose of using DHCP to configuration the host.
