element956
Jan 14, 2019Aspirant
Difference between NetGear ProSafe M5300-28GF3 GSM7328FS and M5300-28GF3 GSM7328S
Hi
What is the difference between NetGear ProSafe M5300-28GF3 GSM7328FS and M5300-28GF3 GSM7328S model?
Thanks
schumaku
Jan 14, 2019Guru - Experienced User
Physical Interfaces RJ-45 Connectors for 10BASE-T, 100BASETX, and 1000BASE-T (Auto Uplink™ on all ports):
-GSM7328S 24 ports
-GSM7328FS 4 ports
-GSM7352S 48 ports
Small form-factor pluggable (SFP) modules for fiber Gigabit Ethernet interfaces:
-GSM7328S 4 slots
-GSM7328FS 24 slots
-GSM7352S 8 slots (4)
10 Gigabit Ethernet/24G Stacking Module Bays
RS-232 Console Port
- element956Jan 14, 2019Aspirant
Is it really a big difference?
- schumakuJan 15, 2019Guru - Experienced User
Well the FS is an Ethernet fiber switch with mainly SFP ports (plus four 1GBaseT) while the S is an Ethernet copper switch with mainly RJ45 ports (plus four SFP) - the switch technology is similar, the FS has some less hardware (Ethernet PHY/MUI) as these are part of the SFP modules or DAC.
