slaviku
Feb 27, 2022Follower
Disabling IGMP Snooping or allowing unregistered Multicast on M4300
Hi, im having an issue with an NTS-PICO3 PTP provider. the tech support of the device suggested to: Reconfigure your switch: Disable "IGMP Snooping" Allow "unregistered Multicast" on Pico3 int...
JohnC_V
Mar 04, 2022NETGEAR Employee Retired
Hi slaviku,
Welcome to our community! :)
To disable IGMP Snooping, Go to Switching > Multicast > IGMP Snooping > Configuration and manually disable the IGMP Snooping. You can also manually disable or enable IGMP snooping per port where the Pico3 interface is connected by going to Switching > Multicast > IGMP Snooping > Interface Configuration.
John
NETGEAR Community Team
