JACK-THINK
Mar 29, 2020Guide
Does M4300 support DHCP Reservation or DHCP Static mapping?
I have a database which contains MAC and IP mappings. I want the built-in DHCP server to assign the designated IP address to the client with the specific MAC address in strict conformity with the dat...
JACK-THINK
Apr 02, 2020Guide
Retired_Member
Thanks for your reply.
I use M4300-12X12F as an Access and Core Switch, only 20 clients are attached to it now. According to the datasheet of M4300(DHCP Server: 2K leases IPv4: 256 pools IPv6: 16 pools), the switch is capable of holding much more MAC-IP mappings than 20. I think it's appropriate to make the number of mappings equal to the number of physical ports on the switch at least.
Thanks a lot.
Retired_Member
Apr 03, 2020Related Content
- Feb 21, 2022Retired_Member
