MM_tech
Nov 30, 2018Aspirant
ERROR: can't get kernel image!
Hi,
Overnight switch malfunction. I managed to connect to the switch with miniUSB console port using HyperTerminal port 23. I switched off/on couple of times. This is the error logs i get. :( ...
boe
Dec 14, 2025Luminary
How do you reset to factory default from the boot menu.
schumaku
Dec 15, 2025Guru - Experienced User
As mentioned before: Strictly follow M4300 Resetting to factory default using the boot menu
Keep in mind "factory default" means an empty config file.
