JLE67
Jun 19, 2019Aspirant
Fans running full speed after 7.0.0.11 upgrade
Hi, I just bought a XS712v2 that came with firmware 6.6.3.3. I updated the firmware using the HTTP procedure as I have no PC with Windows. From what I have seen, the new firmware 7.0.0.11 seems to ...
schumaku
Jun 19, 2019Guru - Experienced User
Fetch the Tech Support Logs/Info and submit it with a problem report on https://my.netgear.com
THere is a thread on this subject on the correct community section (Smart-/Plus-/-Click-Switches) -> switch fans run at high speed after firmware upgrade to 7.0.0.11
JLE67
Hi,
thx for the other thread.
Case opened allready with #41377856 but no news since tomorrow.
Added TechSupport and config files few minutes ago.
Best regards.
