phuketmymac
Jan 15, 2024Aspirant
Fiber cable options for a 10Gb link between a M5300-28G3 and an XS708T
Hello, I have 2 switches to connect with a 10Gb link: - XS708T (8 ports 10Gb Ethernet with 1 combo SFP+ port and without extension slots at the back) - M5300-28G3 (24 Gigabit ports + 2 SFP+ por...
LaurentMa
Jan 16, 2024NETGEAR Expert
Hi phuketmymac ,
If the switches are distant from 20 meters, you could user the NETGEAR 20-meter DAC (AOC) cable called:
| AXC7620-10000S |
This way it would be all in one, with SFP+ connector on both sides.
The AXM763-10000S LRM module is for OM1/OM2 old style 62.5 multimode fiber, it really depends on your fiber, and if you need or not mode conditioning patch cords. Maybe the long DAC cable would be better for you?
- phuketmymacJan 21, 2024Aspirant
I was not aware they had a 20m cable all in one. Thanks I'll check that out.
