advantagecom
Mar 25, 2009Novice
Firmware 7.3.1.7
Has anyone running a GSM or FSM series L3 managed switch tried firmware 7.3.1.7? I'm really curious about stability of this new release. 7.1.1.7 and 7.2.1.6 were not very stable (IP routing, VLAN, ...
advantagecom
Mar 27, 2009Novice
We did go ahead and split our stack and did a test install of 7.3.1.7. All seems ok at first glance except for one thing.
The config directive 'ip http secure-server' seems to be no longer implemented. All config directives beginning with 'ip http' seem to be missing. The manual for this version of firmware indicates I should be able to use that config directive.
That section of the manual states that the web server is on by default. Well, the insecure port 80 server is indeed running and works, but the port 443 (SSL) server is disabled upon upgrade.
When I find a way to re-enable the SSL web GUI, I'll report back.
