advantagecom
Mar 25, 2009Novice
Firmware 7.3.1.7
Has anyone running a GSM or FSM series L3 managed switch tried firmware 7.3.1.7? I'm really curious about stability of this new release. 7.1.1.7 and 7.2.1.6 were not very stable (IP routing, VLAN, ...
jturner
Nov 05, 2009Aspirant
Seems we may be running into the same issues you have for this particular firmware version. Our logs show a bunch of sshd login attempts before it crashes (no reboot) and one can assume after reading your findings that, that is what is going on here too. Have you had any further results with this? Any further issues? Have you had a chance to take a look at the new firmware and see if netgear actually fixed this problem?
