advantagecom
Mar 25, 2009Novice
Firmware 7.3.1.7
Has anyone running a GSM or FSM series L3 managed switch tried firmware 7.3.1.7? I'm really curious about stability of this new release. 7.1.1.7 and 7.2.1.6 were not very stable (IP routing, VLAN, ...
advantagecom
Nov 15, 2009Novice
8.0.0.25 beta is barely functional. I tried an upgrade and the switch got stuck in an endless reboot. After clearing the config at the boot menu, it was finally able to boot properly.
The big issue is that there are so many syntax changes in the commands that converting the config is a tedious and time consuming process. It could probably be done if you had the patience, but expect several hours (at least) of pulling your hair out trying to get the same config you had in 7.3.1.7.
