suraj_s
Nov 18, 2021Aspirant
firmware update 2.0.3.2 to 2.0.6.3
I have GS724TPv2 GE Managable switch with me. The current running firmware on it is 2.0.3.2 and I want to update it to 2.0.6.3(latest available version). Can I directly update from 2.0.3.2 to 2.0.6....
suraj_s
Nov 24, 2021Aspirant
So I can directly upgrade the firmware isn't it?
In instructions I found that the HTTPS will get disabled after the update, currently when I am trying to access the via IP only, it is redirecting to HTTPS, so I hope after upgrading, it wont happen.
JeraldM
Nov 25, 2021NETGEAR Employee Retired
Yes, you can directly upgrade it.
When it comes to accessing the admin page of the switch, you can explicitly type in http://IP_address_of_switch if typing just the IP address won't work.
You can check page 262 of the user manual here if you'd like to re-enable HTTPs access.
