StuSmith
Feb 28, 2020Aspirant
FS728TP Ping Query
Bigger issue than what I will describe below, but I'll shorten it for starters as I think this might be the cause. I've got a number of switches linked together, three of them being FS728TP's, as we...
DaneA
Mar 05, 2020NETGEAR Employee Retired
Make sure that all of your FS728TPv2 switches are on the latest firmware version. The latest firmware is v5.0.2.50 and you can download it here.
About your FSM726 and GS724T switches, what is their specific model number? Is it FSM726v2 and GS724Tv4 respectively? Make sure that both switches are also in the latest firmware version.
The bigger picture is that I want to connect the switches to an NTP server. The GS724T will connect OK (and the server is physically connected to it), but none of the FS728TP switches will connect.
Found out that you are located in UK. Kindly access the link below:
https://www.galsys.co.uk/time-server/uk-time-server.html
Kindly try the steps below:
1. On the web-GUI of the FS728TPv2, go to System > Management > Time > SNTP Server Configuration.
a. In the Server Type list, select DNS.
b. In the Address Field, enter 0.uk.pool.ntp.org (refer to the link I shared above).
c. In the Port field, set it to 123.
d. In the Priority field, enter 1.
e. In the version field, enter 4.
f. Click Add
2. Do the same procedure in step 1 but this time enter another NTP time server.
b. In the Address Field, enter 1.uk.pool.ntp.org (refer again to the link I shared above).
d. In the Priority field, enter 2.
f. Click Add
3. On the web-GUI of the FS728TPv2, go to System > Management > DNS > DNS Configuration.
a. Select Enable on the DNS Status
b. In the DNS Server field, enter the IP Address of your DNS server.
c. Click Add.
As reference, access the article below:
Note: You may also want to try using the equivalent IP addresses of both 0.uk.pool.ntp.org and 1.uk.pool.ntp.org (refer to the link I shared above) and go through the steps above again to further isolate the problem.
About the ping query, let us try below to isolate the problem:
1. Disconnect one FS728TPv2 from the existing network then go to Maintenance > Troubleshooting > Ping. Try to ping the devices directly connected to it. Are you able to get replies?
2. From step 1, set any port to be a member of the Management VLAN. Connect a PC to that port and set a static IP address correctly on it. Then, ping the PC. Are you able to get replies?
DaneA
NETGEAR Community Team
