wvrbe
May 22, 2019Tutor
Full factory reset M4300-52G 48-port without web or terminal access
Hello,
We have trying to find a way to do a full factory reset of a switch that came back from a rental job.
We have no idea on the password to get in the Web GUI.
No access via the ter...
- May 27, 2019
factory reset did not clear the password, we did it via the usb cable to do a recovery and reset the password
wvrbe
May 23, 2019Tutor
Helloa,
After around 6 sec the switch is rebooting even if you keep pushing.
After the reset, the defaul admin with no password does not work.
kevin_hong
May 26, 2019Apprentice
Hello Wvrbe,
After restore-defalut deivce, login dut by Gui do not need password.
You only need to enter username "admin" to login successfully by Gui
- maindriverMay 27, 2019Apprentice
Buy yourself some of these cables..
'Cisco rollover USB ftdi cable'
They are awesome, if you need drivers, they'll be on FTDI website.
Use KiTTY to connect up.
- wvrbeMay 27, 2019Tutor
