MrJonny
Mar 17, 2016Aspirant
GS108E Duplicate Packets found when pinging
Hi Guys, I'm getting GS108E Duplicate Packets when I ping my switch. I saw there was a Firmware Update that fixed this but I have updated it to 2.00.08 and I'm still getting the issue. I hav...
MrJonny
Thanks for your quick reply.
a: no luck
b: no luck
c. tried laptop via wifi -> routor -> switch
d. what do you mean? it just flashes like all the others do.
Also would reflashing 2.00.08, be a good idea?
Windows does not report these extra responces, but all my linux computers do.
Apart from this issue, I have no other problems with the switch.
JohnRo
Mar 17, 2016NETGEAR Employee Retired
Hello MrJonny,
What does "no luck" mean on your previous reply? Does it mean you are not getting a DUP on the pings or does it mean you are not able to contact the switch at all? You can try a reflash followed by a factory default reset again, DUP errors are usually caused by a bad card or bad routing, I think that's what DaneA's is trying to isolate.
Looking forward to your response.
Thanks,
- MrJonnyMar 22, 2016Aspirant
Reflashed and factory reset. Problem still remains.
No Luck. meant I was still getting the same issue.
- DaneAMar 23, 2016NETGEAR Employee Retired
Hi MrJonny,
Since the problem still occurs on one of your GS108Ev3 switches, it might be possible that the hardware is faulty. I advise you to open an online case with NETGEAR Support here. Let them know about the troubleshooting steps we did and still the same problem. Please be ready to submit a soft copy of the Proof of Purchase of the GS108Ev3 that has the problem for warranty verification.
DaneA
NETGEAR Community Team
