cotje's avatar
cotje
Novice
Jan 25, 2014
GS108E FW upgrade OK but no GUI
Hi,
Just upgraded my new GS108E switch and updated the firmware from 1.00.09 to 1.00.12. Upgrade went fine and at 100% the reboot message came. Switch comes back up and I can see it with the Prosafe utility (ip adres was reset to default 192.168.0.239). But when I want to administrer the switch I get:
""boot code requests a firmware download"
If I APPLY is it asking me for the Firmwar-file again, I select the file and then it says:\
"Timeout, no response from agent"
Switchports work fine but I need to now how I can get Prosafe working again. Is there a way te down/upgrade the firmware without the GUI?
Also tried the Factory-default switch but with no results.
Anyone a suggestion?
Thanks in Advance
1 Reply
  • If you done factory default and still have an issues then you may want to put trouble ticket in via portal at my.netgear.com
ProSupport for Business
