55kkaaLL
Aug 09, 2021Aspirant
GS108PE Web access refused
Dear NETGEAR suppport, The following malfunction occurs on five PoE switches(GS-108PEv3) which I purchased recently. * When I accecced by browser, connection is refused. * But, This PoE Swit...
55kkaaLL
Aug 10, 2021Aspirant
Thank you for your responce.
These PoE switchies are in remote site, I will try your suggestion later.
* Confirm model / Firmware version
* Factory reset using the Reset Button process
* NETGEAR Switch Discovery Tool (NSDT)
I will report it if I know a cause
schumaku
Aug 11, 2021Guru - Experienced User
Remote site does read like a typically slightly lower MTU to me - this is a known issue 8-/
- May 25, 2022Anonymous
