cagatayantmen
Jul 05, 2023Follower
GS110MX UpTime ?
Hi, Whats the uptime (ms) when GS110MX power cut off ? Thanks.
michaelkenward
Jul 06, 2023Guru - Experienced User
What do you mean by "uptime"?
The GS110MX is an unmanaged switch.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Switches - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Sep 02, 2018Retired_Member
