Retired_Member's avatar
Retired_Member
Dec 13, 2017
GS108T Switch Uptime wraps to negative uptime
Topic sas it all really:
System Information
Switch Status
Product NameGS108T
System Name
System Location
Idle Timeout  (3 to 30 minutes)
DHCPDisabled
IP address
Subnet mask255.255.255.0
Default gateway
MAC address
System UpTime-117 days -13 hours -16 mins -48 seconds
Versions
Model NameHardware VersionBoot VersionSoftware Version
GS108T1.0.0.1V1.0.0_023.0.4.10
  • Carl_z's avatar
    Carl_z
    Dec 14, 2017
    Hi noibla,
    Thanks for your suggestion. We would check it.
    Best Regards
    Carl
  • Carl_z's avatar
    Carl_z
    NETGEAR Expert
    Hi noibla,
    Welcome to the community ,
    Suggest to access to GS108T web gui and check the system up time.
    From the sheet you provided,we can see DHCP status is disabled,and ip address is blank.  In this condition the GS108T is not accessable.
    To access it, we at least need to set a valid ip address.  To set ip address you can use Smart Control Center , which can be downloaded here
    After ip address is ready , you can log in to the switch via broser. And under the page of "System/Mangement/System Information"  shows the system up time.
    Hope it helps
    Carl
    Netgear Employee
    • Retired_Member's avatar
      Retired_Member
      Hi Carl,
      Thanks for th ereply. I removed the IP addresses deliberately as well as the MAC address. The unit has been on for quite a while and probably looped the counter for the uptime. It is likely that the system uptime is stored as a signed integer, however, due to the lenghtly uptime now overflows to the negative.
      Best to update the system firmware to have this as an unsigned integer.
      • Carl_z's avatar
        Carl_z
        NETGEAR Expert
        Hi noibla,
        Best Regards
        Carl
ProSupport for Business
