Diar
May 28, 2016Follower
GS116Ev2 LACP VLAN
Hi All,
I have the switch configured with Advanced 802.1Q VLANs, additionally I have some LAG, I was expecting the LAGs to appear as Ports under the advanced configs but they do not. On other Netgear switches you add the LAG to the VLAN not the physical ports, but as always the user interface on this switch is different from all other switches. Has any one got LAGs working with advanced 802.1Q Vlans ?
- DaneANETGEAR Employee Retired
Hi Diar,
Welcome to the community! :)
As far as I know, the GS116Ev2 only supports static LAG not LACP. The NETGEAR Smart Switches like the GS108Tv2 supports LACP as well as you can select the LAG ports as members of a certain VLAN via the web-GUI.
DaneA
NETGEAR Community Team
- JohnRoNETGEAR Employee Retired
Hello Diar,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
