Meadster
May 15, 2023Tutor
GS308E - Linked Speed Query
Hi, I have Orbi 850 Router (in AP mode) and 2 satellites as my wireless system around the house. All good. Now, I have used all 4 gigbit ethernet connections on the back as follows: 1 to Sky box...
schumaku
May 15, 2023Guru - Experienced User
After two massive strokes, I'm reading
GS308E
Two ports on Fast Ethernet (100 Mb/s link speed)
- Port 2 (probably the Sky Q 2TB non HDR)
- Port 5 (probably the Sammy TV)
Two ports on GbE (1000 Mb/s link speed)
- Port 1 (probably the Orbi LAN 1 or 2)
- Port 4 (probably the xbox)
Note: Port 3 has no link, so nothing connected or active...
Orbi
One port on Fast ethernet (100 Mb/s link speed)
- LAN3 (probably the Sony Blu Ray Player)
None of the three Fast Ethernet devices, Sky Q 2TB non HDR, Sammy TV, or Sony Blu Ray Player can have an advantage if assigning to suspect faster WiFi connection. Still, it's wireless, the latency can be higher or variable, results are random, ....
That's all, folks, lack of any other information.
