duckware
Nov 05, 2024Prodigy
GS308EP incorrectly claims via UPnP to be a ROUTER/GATEWAY
GS308EP Firmware Version 1.0.1.4 claims "You can use Universal Plug and Play (UPnP) protocol to discover the device"... OK, let's test that. In response to a "ssdp:discover" for "ssdp:all", the...
ReneD
Nov 06, 2024NETGEAR Moderator
Hello duckware,
And welcome to the NETGEAR Community! 🙂
Thank you for sharing this and it is best for our Engineers to look at it for a possible bug on the switch. It will be best to open a Netgear support case so they can open an Engineering ticket to investigate this issue.
Have a lovely day,
Rene D
Netgear Team
- duckwareNov 07, 2024Prodigy
I already contacted Netgear support and like always, Netgear support is not capable of understanding what the bug is. The full response from Netgear support was:
Greetings from NETGEAR!
Kindly find the below kb article for UPnP,
https://kb.netgear.com/000066307/GS308EP-Firmware-Version-1-0-1-4
Please follow the above steps.
==============================- schumakuNov 07, 2024Guru - Experienced User
Not really a bug, much more an almost common default design and implementation issue - reported on almost any other earlier Plus switch model and similr models I had in Bet testing. Of course, engineering does understand what requires to be changed - away from the ubiquitous default "router" product implementation.
