ebaruk
Aug 26, 2023Aspirant
GS308EPP access over the OpenVpn remote connection
Hi, I have problem accessing the switch over the OpenVPN. The switch is set to fix IP: 10.0.80.1x Number 80 represents my VLAN 80 which is my manegement VLAN I do understand that the switch...
schumaku
Aug 28, 2023Guru - Experienced User
ebaruk wrote:
a)
If I set the static IP which is NOT in a group of my VLAN's and NOT in my management VLAN...for example 10.0.1.11x then I don't have any problems connecting to the device over the VPN or any other remote connection.
Sorry, I don't understand what you want to explain, and much less why this should magically work there.
ebaruk wrote:
Hope if someone can explain me if and how can I gain access to my switch if I set it's static IP in one of the VLAN's which differ from VLAN 1 (NATIVE)
The VLAN your are using for bringing the VLAN to near to the switch can't have any relevance. The point is the uC can understand untagged frames as for the IP stack where the Web UI is accessible. Any VLAN can be used - there is nothing left from the VLAN ID used the moment the frames are untagged. Note: There is no native VLAN 1 known in any way by this unmanaged switch.
ebaruk
Aug 28, 2023Aspirant
Thanks for fast reply...
Maybe my explanation/question is a bit complicated...due to the fact I'm not an IT expert and just being "home network entusiast"... I aplogise if I ask "stupid" questions..
Anyway.. My idea was to manage the switch over my existing management VLAN 80 (I use this VLAN "80" to acces all of my devices when doing management --> routers, managed switches, AP's, cameras,....)
For that purpose I set static IP in the range of VLAN 80 (10.0.80.11x) but not able to access the SWITCH from the "outside".. regardless what I try...
If on the other hand I set the static IP address of the switch as non VLAN range e.g. 10.0.1.11x which is not a member of any VLAN... I can easily access the switch for the management (OpenVPN, ....)
So my main question is... If this is expected/logical switch behaviour due to the fact it doesn't have option to set up "management VLAN"... or I should still be able to access the switch remotely even if I define the static IP address in the range of my management VLAN... as explained above ?
- schumakuAug 28, 2023Guru - Experienced User
Makes perfect sense.
Subnet mask and default gateway correctly configured?
Look, these switch config uC does not care about any VLANs. Figure out what makes the difference on the two configs please.
