BillyGrace
Nov 29, 2021Initiate
GS516TP - SInce installed I now cant see my CCTV Cameras via the main outside IP Address??
Hi I changed from an unmanaged Prosafe 8 port to the GS516TP - SInce installed I now cant see my CCTV Cameras via the main outside IP Address?? What am I missing? Thanks My port...
- Dec 07, 2021
Yes problem sorted
The switch inst blocking any ports.. I had to change the settings on the Hikvision DVR
mtechina
Dec 07, 2021Aspirant
BillyGrace wrote:Hi
What am I missing?
My ports are open on my BT Router
Hi, have you found the solution,? i was actually facing the same problem.
- BillyGraceDec 07, 2021Initiate
Yes problem sorted
