Al05
Apr 03, 2018Follower
GS516TP Inter VLAN access
I have a GS516TP Pro-Switch and the hardware below: ISP Huawai Router LAN IP 10.0.0.1/24 DHCP 10.0.0.2/170 GS516TP LAN IP 10.0.0.111 Subnet Mask 255.255.255.0 VLAN 1 Default...
JohnC_V
Apr 05, 2018NETGEAR Employee Retired
Hi Al05,
Welcome to our community! :)
GS516TP only supports L2 routing and it isn't what we call a managed switch. You may need to configure static routes on your router in order for you to communicate those VLANs as they are working on different router setup or better yet replace the switch with a fully managed switch. How do I configure VLAN Routing on a smart switch? You may still try to test if this will work on your setup.
Here is the list of fully managed switches.
