edfsr
Oct 31, 2022Follower
GS724Tv4 VLAN Configuration
I have a pfSense firewall that currently routes traffic between the internet, my private LAN, a DMZ with web and mail servers, and my wireless networks. I would like to use my Netgear GS724Tv4 ...
schumaku
Nov 01, 2022Guru - Experienced User
Fist you need a plan on how you intend to use the VLANs and the related ports and LAG which make up a logical port where you can apply VLAN configs again.
Next define which VLAN(s) connect to a device, to another switch, and how you intend to use it. should the port resp. the LAG connect to a computer for just single VLAN, to a wireless access point serving multiple SSIDs and VLAN.
A dead simple VLAN configuration bringing a bunch of ports together in just one dedicated network (access ports) is demonstrated here https://www.youtube.com/watch?v=6fQPHPvcBmI
A slightly more advanced example with some trunk and access port config examples is here https://www.youtube.com/watch?v=fU3D0_JUoss
The beauty is that almost all makes and switch feature sets are using the same logic.
