dluechtefeld
Mar 12, 2018Aspirant
GS752TP v6.0.1.118 not presenting LLDP SystemName to Cisco 3750G
My Netgear GS752TP is connected to a Cisco Catalyst 3750G. Both have System Names set, and LLDP is enabled TX/RX on the connected interface. I can see the CIsco neighbor's System Name, but the Netgea...
JohnC_V
Mar 15, 2018NETGEAR Employee Retired
Hi dluechtefeld,
Welcome to our community!
GS752TP only supports standard LLDP. May I know if the NETGEAR switch can recognize other devices in the LLDP? It seems that you are just seeing this from the cisco. Have you checked the NETGEAR if it can see other devices?
schumaku
Mar 15, 2018Guru - Experienced User
Mandatory vs. optional TLV types -> Wikipedia: Link Layer Discovery Protocol - Frame_structure
- dluechtefeldMar 15, 2018Aspirant
OK, how do I set the Chassis ID to something more meaningful? The MAC address is not very identifiable.
