hunte88
Jun 19, 2023Aspirant
GS752TPP poe problem with hikvision
Hi, i have bought a switch model GS752TPP to change my old ubiquiti switch 24p 500watt poe. With ubiquiti i not have a problem with a ipcamera that is distance 70 meters with cable ethernet, from th...
schumaku
Jun 19, 2023Guru - Experienced User
Time for a firmware update and adjust the PoE detection time for this specific issue.
https://kb.netgear.com/000065651/GS728TPv2-GS728TPPv2-GS752TPv2-GS752TPP-Firmware-Version-6-0-10-17
Consult the release notes FMI.
- hunte88Jun 19, 2023AspirantI have updated the firmware but the problem persist. For adjuts the time detect what i must to do exactly ?
Thanks a lot for the help.- schumakuJun 19, 2023Guru - Experienced UserCheck the System > PoE > Advanced > PoE Port Configuration page
For simplicity, I suggest to change the negotiation time for all ports.
Post a screenshot of the complete table, and we figure out together in case.- hunte88Jun 20, 2023Aspirant
Hi, in the page of POE configuration i see on the left, what must i do for setting it ?
You speak of negotiation with ipcameera but is on other menù, (see on the right) and i already setted on full for negotiation but the problem persist.
