lcs0500
Jan 12, 2018Aspirant
GSM5212 voice VLAN killing LAN access for Yealink T42S phones
Objective - I'm trying to set up 3 T42S phones for a 3cx pbx installation on an OVH vps in STUN configuration behind a Netgear M4100-D12G switch using the Auto-Voice VLAN. The router is a Netgear R...
lcs0500
Jan 15, 2018Aspirant
Thank you both for the suggestions and reference documents.
I have decided to replace the router with one designed for business use.
It seems to me that, with only 3 phones, a business router would eliminate the need for a managed switch.
Please let me know if that isn't correct.
Thanks,
Lou
schumaku
Jan 15, 2018Guru - Experienced User
This does lead to the question if there is a need for a business router and a managed switch if there are just three IP phones at all?
