Seb06
Sep 23, 2017Aspirant
GSM5212P SNMP OID for reading Ouput Voltage and current and pethPsePortAdminEnable.X command
Hello to the community, I try to read output POE voltage and current from a GSM5212P and a also need to switch on and off a port with pethPsePortAdminEnable.X via SNMP. I find only a limite...
DaneA
Sep 25, 2017NETGEAR Employee Retired
Hi Seb06,
I just want to confirm. Since you are already using the latest firmware v10.0.2.26, are you also using the latest MIB v10.0.2.26? If not yet, kindly download it here, then use it. Let us know if it helps.
DaneA
NETGEAR Community Team
- Seb06Sep 25, 2017Aspirant
Hi DaneA,
Yes I use MIB file v10.0.2.26.
Seb06
- DaneAOct 03, 2017NETGEAR Employee Retired
I just got a feedback from the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, according to SNMP Supported MIBS on the GSM5212P switch, the POWER-ETHERNET-MIB is a supported MIB. Within the POWER-ETHERNET-MIB, the value pethPsePortAdminEnable is present so this should work.
May we know what SNMP tool are you using?
DaneA
