DarkMata
Aug 05, 2015Aspirant
GSM7224 allow only one MAC
Hello I configure 802.1x with Microsoft Radius Server but some device are old and dont understand this 802.1x, so i need another Way to protect my Switchports. I am not sure but the only way to giv...
DaneA
Aug 05, 2015NETGEAR Employee Retired
Hi DarkMata,
I just want to share these articles below if ever you have not came across with it yet and these might be helpful to you:
What is port security and how does it work with my managed switch?
How do I configure a protected port to isolate ports using CLI commands on my managed switch?
How do I configure a protected port to isolate ports using the web interface on my managed switch?
Hope it helps.
DaneA
Netgear Community Team
- DarkMataAug 12, 2015Aspirant
Hi
And this is the only way to protect my network from this device?
Because its very easy to fake a MAC Adress.
So i make a Security Port with 0 Dynamically Learned MAC Adresse and only 1 Statically Locked MAC Adress and this port is "Secure" :)
