DarkMata
Aug 05, 2015Aspirant
GSM7224 allow only one MAC
Hello I configure 802.1x with Microsoft Radius Server but some device are old and dont understand this 802.1x, so i need another Way to protect my Switchports. I am not sure but the only way to giv...
DaneA
Aug 05, 2015NETGEAR Employee Retired
Hi DarkMata,
I just want to share these articles below if ever you have not came across with it yet and these might be helpful to you:
What is port security and how does it work with my managed switch?
How do I configure a protected port to isolate ports using CLI commands on my managed switch?
How do I configure a protected port to isolate ports using the web interface on my managed switch?
Hope it helps.
DaneA
Netgear Community Team
DarkMata
Aug 12, 2015Aspirant
Hi
And this is the only way to protect my network from this device?
Because its very easy to fake a MAC Adress.
So i make a Security Port with 0 Dynamically Learned MAC Adresse and only 1 Statically Locked MAC Adress and this port is "Secure" :)
